| | | Forums66 Topics128,022 Posts1,055,376 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 83 | I'm reassembling my '41 pickup during the final stages of restoration. Today I installed the passenger side door and then attached a new side mirror. I'm either doing something wrong, or else these mirrors are designed really poorly. When you open the door about 3/4 of the way, the mirror bangs into the door glass. Anyone else have this problem? What is the solution? Here are some pictures of my door/mirror. http://s950.photobucket.com/albums/ad342/summerfi/41%20chev/ | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I see your problem, that tab with the small hole needs to be inside the door jam. Also there is a screw that goes through that hold to keep it in place. Take it apart and start over. | | | | | Joined: Nov 2010 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 83 | Ohhhh....that makes sense. Thanks much for the help.  | | |
