0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#797371 11/13/2011 1:42 AM
I'm reassembling my '41 pickup during the final stages of restoration. Today I installed the passenger side door and then attached a new side mirror. I'm either doing something wrong, or else these mirrors are designed really poorly. When you open the door about 3/4 of the way, the mirror bangs into the door glass. Anyone else have this problem? What is the solution? Here are some pictures of my door/mirror. http://s950.photobucket.com/albums/ad342/summerfi/41%20chev/
My toys:
'41 Chevy Model AL 3/4 Ton
'40 Chevy Model KD 3/4 Ton
Hinomoto 209N Tractor/Backhoe
Norwood LM2000 Sawmill
PJ 16' Trailer
and a Brand New Shop!
Be what you is, not what you ain't, 'cause when you is what you ain't, then you ain't what you is.
summerfi #797373 11/13/2011 1:59 AM
I see your problem, that tab with the small hole needs to be inside the door jam. Also there is a screw that goes through that hold to keep it in place. Take it apart and start over.
1946 1/2-Ton Chevy
Ohhhh....that makes sense. Thanks much for the help. smile
My toys:
PJ 16' Trailer
