5 members (Randy Baumann, TexasJim50, 52Carl, dt235sd, 1955 1 Series), 77 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#79737 07/09/2007 6:03 PM
I have come to the phase of my project where I need to pull the transmission. I have removed disconnected the various items attached to it and only need to remove it from the engine. Hence the confusion. I was told to by to 1/2 bolts about 4" long and use them in place of the upper bolts to slide the transmission out. I have to turn down the bolts alittle because the bind and on the sides of the transmission but this isn't a problem the problem the two lower bolts. Where are they? I scraped what seems to be tons of grease and dirt of the transmission and there still MIA Any one have pics or something to tell where to find these bolts.
Oh and sorry for the long post. :hammering:
#79738 07/09/2007 6:08 PM
Inside the bellhousing. They screw into the tranny, opposite what the top bolts do.
Bob
#79739 07/09/2007 6:19 PM
Delux,
The two long guide bolts you mention do help a bunch, but are usually reserved for the installation of the transmission. They serve no real purpose when pulling things apart...in my opinion.
Stuart
#79741 07/09/2007 6:36 PM
Ron,
If you aren't well versed in the art of stabbing a transmission, the long bolts help you align things for a straight shot, plus allow the transmission to hang so you can wipe your brow and grab a gulp of beer! smile
Stuart
#79743 07/09/2007 7:45 PM
Ron,
I have never used the magic alignment bolts...always did it 'your way'! There are people on this site who don't even know what a creeper is and have never seen a clutch or pressure plate, not less have a transmission jack. If the wife is in the cab pulling on the shifter and the old man is under the truck pushing for all he is worth, why not cheat a bit and let two bolts steer you in for a perfect landing. Everyone has a different level of experience. smile
Stuart
#79744 07/09/2007 7:46 PM
1 Offline
at 46 those 2 "scrawny" bolts i've used for years have help keep me from being the "scrawny one" by saving my back. i do remember being told: work smart not hard! combined with a 4x4 wooden jig and a hand cranked boat winch inside the rig they have earned their place in my tool box.
#79746 07/09/2007 10:59 PM
I've never needed to use alignment rods myself but I think those who do install them before muscling the trans around, not once you are sliding it home. At the home shop, I use a floor jack with an attachment. I like to get it started through the T.O. bearing then I push and wiggle it the rest of the way in. At work I cheat and use a hoist and tranny jack. I've also heard tale of using a cherry picker through the floor when R&R'ing 4 speeds.
To each their own,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
