1 members (1 invisible), 177 guests, and 0 robots.
Topics128,190
Posts1,057,342
Members48,469
I am starting to put back together my 49 chevy 5 window P/U. I have a complete set of wiring that I bought with the truck it came in pieces. I had all of the body pieces painted and have the cab installed on the frame. Now want to start wiring but it would help if I had some pictures of what the wiring looks like under the hood. Does anyone have any pictures like this? I do have a wiring diagram and wire numbers that came with the wiring.
Bennie
Where in Illinois are you located Bennie? If you're anywhere around Sandwich I'd take a
drive over and you could look at my '50 which should be quite similar.
It’s pretty hard to show all the wiring under the hood but here are a few pictures:
http://www.pbase.com/dennygraham/image/134293408
http://www.pbase.com/dennygraham/image/137963486
http://www.pbase.com/dennygraham/image/115069341
http://www.pbase.com/dennygraham/image/115069445
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
The '49 will be a little different. It'll have what, 5 fuses? Here are some pictures of my '49 before I stared work on it. I can take some more if you want.
http://i221.photobucket.com/albums/dd45/HomeCrafter/IMGP1714.jpg
http://i221.photobucket.com/albums/dd45/HomeCrafter/IMGP1713.jpg
Pay no attention to my enormous voltage regulator, its some sort of industrial generic replacement (along with my FoMoCo generator).
Hope this helps.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Hi Denny,
I live in South Elgin which is not far from you. If you give me your address and phone number I would love to take a drive on a weekend and look at your truck. I loved the pictures you sent I was wondering how the stop light switch mounted. on the clutch picture is that a rubber bumper to keep from hitting the firewall? My e-mail is [email protected] and my cell phone is 847-899-2585 look forward to hearing from you
Bennie
Thanks this helps a lot I do have a 5 fuse box and it is located in the same as yours If I need more pics I will get back to you thanks for taking time you took by the way where you located? I had another answer from a guy not far from me
Bennie
I'm in Canada, on Vancouver Island. I think there are some illustrations of the wiring harness in the shop manual as well. It's pretty straight forward, but slow and methodical process.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
