| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 59 | On my truck (53 3800) Im trying to figure out what type of generator it has on it. Everything thing is 12V including headlights and regulator. Im wanting to go through it and put new bearings and brushes.. everything esle looks pretty good. I see there is what looks to be a casting number on the armature and maybe a 3 digit number on both ends. It has the roller bearing in the rear cap which makes me think it is a heavy duty model?? It has no tags on it. Can anyone help me with this? Would like to check for shorts and get a rebuild kit but im not sure about the model number or type of generator it is.
Thanks!!
Daniel
1953 Chevrolet 3800 Stepside
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Roller bearings? The Oldsmobile and Cadillac 45-amp generators had ball bearings on both ends, and a long housing with a step-down about 3 inches from the back end. Try looking up parts for an early-1960's Olds 98 generator or one for a Cadillac Fleetwood of about the same vintage. I think the last year for generators for those cars was 1961 or 62. Jerry
| | | | | Joined: Sep 2010 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 59 | Sorry about that.. Yes it has ball bearings on both ends.. Both bearings are the same size. Yeah it does have the step down about 2 inches from the back.. about 4 inches in diameter. It looks like they have retrofitted another bracket on it because the bolt slots for the engine bolts have torch cuts in them
Daniel
