6 members (walter74, Lightholder's Dad, Millenimech, Wayne67vert, 1955 1 Series, 1 invisible), 158 guests, and 4 robots.
Topics128,209
Posts1,057,462
Members48,471
Hi all. I am in need of a fan blade for my 58'-62' 235. I have found a guy locally who has a few to choose from, a 20" and 17"; both have the same mounting holes that my fan pully does. I'm pretty sure the stock fan size is 17", but since I live in AZ and summers get pretty darn hot, should I get the 20"?
How wide is your radiator? You sure don't want the fan to be wider than it is because you will defeat your purpose. My Stock rad on my GMC is around 19 so a 20 fan would be wrong for me. I also live in hot summer country and I'm even considering a shroud later to help in my cooling.
"when I grow up - please go ahead and dig my grave!"
I'll have to check, I was told it is the stock radiator. The engine is going in my 1959 Apache
Stick with the stock size. It is more than enough even in the hot weather areas. Unless your an aerodynamicist please don't try to re-invent that which has been professionally engineered. Keep it the same distance from the radiator as original.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
So I was correct about the 17" blade being stock size? I have a fan shroud that is 19" in diameter, it was given to me when I bought the truck. Could I use that with that 17" fan, is the the size difference too much?
I measured the width of my radiator and it is around 21". So not putting the fan shroud in the equation, it looks like the 19" fan will work, right?
One thing that I learned when I installed a shroud on my '55 Bel Aire was that the fan needs to only be located halfway into the shroud for it to work properly. So be sure and do your homework. You may have to use a different spacer or even modify the shroud but they do make a difference if installed correctly.
