8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,140 Posts1,056,770 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | Casting number is 364747. I'm trying to find out what vehicles it was used in, what the part number is if the casting number isn't the same as the part number and what the corresponding part number is for the passenger side. I've searched various sites and have not been able to locate any info. Thanks! | | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | Sorry I don't. A friend has this and said it was the one to get for the truck I'm building. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | those have the smog fittings on them....i'd keep looking....you can find that same style without the fittings....i have them on mine......dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | It's the one you need because it's the one he has.  I agree with David..keep looking.. however those smog fittings can be plugged with readily available hardware from a plumbing supply. Sorry I don't. A friend has this and said it was the one to get for the truck I'm building. | | | | | Joined: Jun 2011 Posts: 150 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 150 | Joe, I think I found it. It is for a 1975 C10 (among others?). The reason I wanted this one is because it allows extra clearance for the steering shaft and also since it is a truck application, it is set up for torque. I'll see if I can post the link. http://www.autopartswarehouse.com/s...mp;intcmpid=Product+Listings+Best+Seller | | |
