1 members (klhansen),
158
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 39 New Guy | | New Guy Joined: Sep 2011 Posts: 39 | I am changing the oil in my 1951 1/2 ton, 216 ci, for the first time and would like to know what weight oil is recommended.
My manual calls for 20W oil for temps down to 10 degrees. This information is from a 60 year old manual, so I would like to know what weight oil is the best to use by today's standards. The truck does not have an oil filter and is not road ready at this time. I will not be driving the truck during the winter but will start it weekly up to keep it loose. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I have used Quaker State 10W30 in all my vehicles since I was a teen including my 49 half ton. Always worked for me although my trusted mechanic says 10W30 is basically generic oil and I should use something else. I had a by-pass filter on my 49 but removed it as I change oil every 1000 miles and even then it seems clean. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I use 10W-30 in my '48 as well. I'm not so sure 10W-30 was in production when I was a teen, though... | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | My truck is about the same setup: 216, no oil filter, not road legal, but runs. I use the standard oil off the shelf, 10W-30. There are a lot of comment threads about engine oils, but since you'll probably be changing it again in spring before any leisure drives, a modern multi-viscosity oil should do for your winter truck warm-ups. If it regularly gets terribly cold (like below 0°F), you could even use 5W-30.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
