2 members (John Dlugos, 1 invisible), 150 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
I'm getting close to bolting my bed back on the frame. I'm wondering if I need those bed to frame rubber mounting pads? I read a thread on another forum and it looked like the opinions were leaning against using them. One of the main reasons was that they threw off the alignment of the bed and cab. I don't remember there being any pads when I removed the bed.
All opinions and experience welcome!
Tom
1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
Yes, get the pads. Otherwise the bed frame will rub against the truck frame. As far as alignment of the bed, that is done prior to tightening up the bed frame bolts (6) for the short bed. Even if its a long bed, your only talking about $8-10 for the pads.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
Although not original, the bed cross sill-to-frame perches are a good idea. As stated above, it avoids the metal-to-metal contact. At 1/8" thick, the bed-to-cab alignment, is insignificantly effected.
Also, there is some flexibility in the elevation & alignment of the cab, so that is an option, when trying to get body-lines in order.
On my fleetside, the side trim looked off when using the rubber pads. If yours has no side trim, you'll be OK.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Thanks guys! I don't have any side trim so I get a set. Hopefully when I have family over on Thanksgiving I'll enlist a couple of brothers and brothers-in-law to help put it back on the frame.
Tom
i have a set of rubbers.
