0 members (),
52
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | I'm getting close to bolting my bed back on the frame. I'm wondering if I need those bed to frame rubber mounting pads? I read a thread on another forum and it looked like the opinions were leaning against using them. One of the main reasons was that they threw off the alignment of the bed and cab. I don't remember there being any pads when I removed the bed.
All opinions and experience welcome!
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Yes, get the pads. Otherwise the bed frame will rub against the truck frame. As far as alignment of the bed, that is done prior to tightening up the bed frame bolts (6) for the short bed. Even if its a long bed, your only talking about $8-10 for the pads. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Although not original, the bed cross sill-to-frame perches are a good idea. As stated above, it avoids the metal-to-metal contact. At 1/8" thick, the bed-to-cab alignment, is insignificantly effected.
Also, there is some flexibility in the elevation & alignment of the cab, so that is an option, when trying to get body-lines in order.
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | On my fleetside, the side trim looked off when using the rubber pads. If yours has no side trim, you'll be OK. | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Thanks guys! I don't have any side trim so I get a set. Hopefully when I have family over on Thanksgiving I'll enlist a couple of brothers and brothers-in-law to help put it back on the frame.
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | | | |
