1 members (baldeagle), 39 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#795544 11/06/2011 3:27 AM
on my 1951 235 the line that comes up to oil the lifter a very small line has acompresion fitting that attaches to a tube goes thru the oiler and then curves down. The tube is loose can pick the top portion out looks like it was soldered in place at one time also loose by the compresion fitting,Sorry i can't be more spcific but doesn'nt seen rite any suggestion. Should that tube be replaced and whats it called? Thanks Bob
bob1 #795550 11/06/2011 3:47 AM
It sounds like you are talking about the rocker oil connector.
The overflow tube should be soldered in place. I sometimes use a wire tie to hold one that has broken loose in place.
My Blog
Thanks Dave do You know that over flow tube is two pieces Thanks Bob
bob1 #795553 11/06/2011 4:12 AM
I think the tube was one piece with the side cutaway inside the connector. Here is a PIC.
My Blog
