| | | Forums66 Topics128,060 Posts1,055,836 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 11 New Guy | | New Guy Joined: Sep 2011 Posts: 11 | on my 1951 235 the line that comes up to oil the lifter a very small line has acompresion fitting that attaches to a tube goes thru the oiler and then curves down. The tube is loose can pick the top portion out looks like it was soldered in place at one time also loose by the compresion fitting,Sorry i can't be more spcific but doesn'nt seen rite any suggestion. Should that tube be replaced and whats it called? Thanks Bob | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It sounds like you are talking about the rocker oil connector. The overflow tube should be soldered in place. I sometimes use a wire tie to hold one that has broken loose in place.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2011 Posts: 11 New Guy | | New Guy Joined: Sep 2011 Posts: 11 | Thanks Dave do You know that over flow tube is two pieces Thanks Bob | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I think the tube was one piece with the side cutaway inside the connector. Here is a PIC.
