6 members (Guitplayer, Gdads51, Gray_Ghost, sron48, MRMEROTH11, 1 invisible), 89 guests, and 0 robots.
Topics128,068
Posts1,055,882
Members48,428
#795012 11/03/2011 11:49 PM
This is how she looks so far. It's a 49 Chevy PU with all 74 Camaro parts. Since this picture I have installed the carb and distributor.
http://img.photobucket.com/albums/v518/Blacktailer/IMG_5002.jpg
I am ready to send the cab, fenders and bed out to paint as soon as I find someone local to do the work. Seems like everything I want to do next like brake lines, wiring, etc. needs to have the cab mounted. What else can I get done other than exhaust while I wait for the paint?
Super charger. HAHa no not much. You could run the wiring along the fram that gonna go to the tail lights or drop in the rear mounted fuel tank and fuel lines. But not much to do. Alway nice to have the body on and ready for assembly.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
You could still use a driveshaft.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Yeah, I'll probably get some exhaust manifolds on it and take it down the to muffler shop and then get the driveline finished. That and the fuel tank/lines.
You can still run the brake lines. Just put a couple of junction fittings where you want to turn vertical at the firewall ( assuming your going with a firewall mount on the booster & Master Cylinder. You should at least get the cab in for paint as this will allow lots of work to be completed once mounted.
1940 Chevy KC 1/2-Ton
Rebuild your gauges
Upulster the seat
Polish/clean the glass
Rebuild the running lights
Polish or send bumpers out for chrome
Polish or send trim out for chrome
Get organized! Make sure you have all the grommets, pads, blocks, antisqueek, fender welt, bolts, washers, nuts, and body gaskets you need for the body assembly.
Sort of stock 1950 Chevrolet 3100
235 (The engine shread) (Engine assembly)- 4 speed - 12 bolt - stock front axle with power disc brakes
I would check with the muffler shop to see if they would prefer to mount exhaust when the bed is on.
~Jim
