0 members (),
110
Mod | | | Forums66 Topics128,183 Posts1,057,264 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | I'm trying to put in a electric fan on the outside of the radiator. Can I cut off the cross braces on the support bracket? I went with the four core radiator and there is only about an inch between the radiator and the short shaft pulley. I have a mustang 2 frontend. will that keep the frontend from flexing or will it still compromise the radiator? thanks | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The radiator core support is the "backbone" of the entire front clip and as such I believe removing them will have consequences but you should be able to add gussets or other reinforcement to replace lost stability.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | the top two corners are squared off. I could make some brackets for the corners. the bottom is angled. I have the fan mounted to the crossing support bars right now. It seems to lose alot of volume thow the radiator. It's a 16" reverseable electric fan but it just doesn't seem to push that much air. | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | You can cut off the 2 cross support bars and still be okay. I don't have them on my 50 3100 and everything lines up okay. I also changed out the stock radiator. I'm still using the water pump mounted fan but I have a 16" fan I'm going to mount and do away with the old style fan
| | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | I'm trying to make a shroud around the fan out of a piece of plastic. The shroud will go through the cross bars to the radiator. thanks for all the help ! | | |
