I stopped by and gave it a quick once over. It looks good and is pretty much original.
I went back and checked the truck out more thoroughly. My original statement, "pretty much original" was a gross error in perception.
It had been chopped, or was in the process of. I'm guessing that it had been converted to power steering with an automatic transmission. The crossmember where I believe the original transmission sat had been cut out from the frame by an arc welder. An angle iron had been welded in and then cut out. A piece of chain had been weldede on the frame in the area of the engine, for what I don't know.
Anyway- in its present condition, it's not worth $1500. I could use the cab, left door, and fenders. Separately, I currently have found those for about $950.
So, I'll eventually make the Owner an offer for no more than $1000, but he'll probably just laugh in my face.
I'll keep you posted.
