| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 51 | I have what is supposed to be a 327 from a 63 Impala with a powerglide bolted to it.
The number cast into the block is 3849852.
Can someone tell me please what information comes up with that number?
and
I would like to change out the 3 on the tree and install this powerglide.
Is there a certain crossmember I need to be able to use this trans in a 64 C10 short stepper and could someone suggest a floor shifter I should buy?
I picked up a tilt steering from a motor home already.
Thanks in advance | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | 3849852 = a 283 .... to replace a standard with an automatic you need a trans mount crossmember, either factory or aftermarket Bill | | | | | Joined: Aug 2011 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 51 | Well I answered my own question. It is in fact NOT a 327 as I was told but a 283 from a car/truck application. Can't be any more specific than that I guess.
And yes Squeeze I do know I need a cross member. The question is, which crossmember do I need? Out of what vehicle? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you can get more specific if there's still a stamped number on the pad at the front bottom of the right side head, or you locate the date code on the block .... you need a universal trans mount cross member from a store or the factory [riveted on] one for a 60's light truck, doubt you'll find one from anything else that would work properly without some engineering and more work than it's worth | | | | | Joined: Aug 2011 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 51 | I looked at the motor once again and at the back of the block, on top where the trans bolts up is a C16 with the number 3 above it.
The number 3252 and the letters HB are cast onto the block also.
If that helps identify the engine a little better I would appreciate some information.
I'll run around the junk yards and see if I can scare up an auto trans crossmember, but I don't like my chances. | | |
