1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#794552 11/02/2011 2:53 PM
I have what is supposed to be a 327 from a 63 Impala with a powerglide bolted to it.
The number cast into the block is 3849852.
Can someone tell me please what information comes up with that number?
and
I would like to change out the 3 on the tree and install this powerglide.
Is there a certain crossmember I need to be able to use this trans in a 64 C10 short stepper and could someone suggest a floor shifter I should buy?
I picked up a tilt steering from a motor home already.
Thanks in advance
AzMcCoy #794562 11/02/2011 3:36 PM
3849852 = a 283 .... to replace a standard with an automatic you need a trans mount crossmember, either factory or aftermarket
squeeze #794734 11/03/2011 1:20 AM
Well I answered my own question. It is in fact NOT a 327 as I was told but a 283 from a car/truck application. Can't be any more specific than that I guess.
And yes Squeeze I do know I need a cross member. The question is, which crossmember do I need? Out of what vehicle?
AzMcCoy #794786 11/03/2011 2:47 AM
you can get more specific if there's still a stamped number on the pad at the front bottom of the right side head, or you locate the date code on the block .... you need a universal trans mount cross member from a store or the factory [riveted on] one for a 60's light truck, doubt you'll find one from anything else that would work properly without some engineering and more work than it's worth
squeeze #794818 11/03/2011 4:43 AM
I looked at the motor once again and at the back of the block, on top where the trans bolts up is a C16 with the number 3 above it.
The number 3252 and the letters HB are cast onto the block also.
If that helps identify the engine a little better I would appreciate some information.
I'll run around the junk yards and see if I can scare up an auto trans crossmember, but I don't like my chances.
