0 members (),
133
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 9 New Guy | | New Guy Joined: Nov 2010 Posts: 9 | hello, i have a 39 to 46 chevy pickup, having trouble finding out the exact year it is, the plate looks like 39 to 41 the vin# consist of numbers and ( yr) or xr, i cant find any refrence for these letters to tell the year is any help will be great | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Most states used the engine number as the "vin" through '55. If you have the data plate with the unit serial number on it, post that number and we'll try to help. On my '38 the unit serial number is 5HB05 then the sequential number showing the order it was built in. The 5HB05 in my case shows it was built in Kansas City (5) is a 1938 Master (HB) and was built in May of 1938 (05). Your numbers of course will differ but will help decode your truck.
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Old Nut Check out Brads site. Maybe will help. Have fun and good luck Dan | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | '39-'40 changed hood and grille in '41 to '47.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Maybe I can narrow it down a bit... '39 has round gauges, no parking lights on fenders. '40 has rectangular gauge package, park lights on fenders 41 - 46 has " waterfall " grille, headlights mounted on fenders | | |
