4 members (Hotrod Lincoln, KCMongo, Peggy M, eclector), 166 guests, and 2 robots.
Topics128,034
Posts1,055,533
Members48,425
#793749 10/30/2011 10:58 PM
Kind of a general question, but what exactly is the voltage gauge in my dash reading? Is it supposed to be the battery voltage? Because my dash gauge always reads about 1 volt off from when I check across the battery terminals with a voltmeter.
When my truck is running, the gauge will read one volt higher, and when the truck is not running but the key is on, the gauge will read one volt lower than across the battery terminals.
Just curious if this is normal?
System is 12 volts, if it matters.
1940 Chevy 1/2 ton, 12 volt, 350/350th
stevebolt #793792 10/31/2011 1:09 AM
A dash gauge is not always an accurate gauge. Learn what is normal for your truck then watch for variations from normal.
Cletis #794140 11/01/2011 3:43 AM
Sir Searchalot
Sir Searchalot
It shows, as you know, that your charging system is putting volts into the battery as you are using volts so that battery stays fully charged. One volt more when running is exactly right. You should have approx. 12.5V not running and 13.5V to 14V running. Battery full charge accross posts = 12.6V/12.7V. Higher charge rate than 14.5 no good , lower than 12.5 no good. If it runs in the "normal" range, as Cletis says, that's all you want. If you see an overcharge or undercharge, time to troubleshoot.
bartamos #794467 11/02/2011 3:47 AM
When did we move from Amp gauges to volt gauges and why did we move?
~Jim
Sir Searchalot
Sir Searchalot
Read "no power" in this forum.
bartamos #796253 11/08/2011 10:53 PM
Ammeters require heavy wiring, and manufacturers are cheap smile But, seriously, they will tell you an ammeter only shows charge or discharge, and doesn't show the condition of your battery, where a voltmeter will.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
