1 members (Hotrod Lincoln),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 89 | Has anyone installed a dome light in their 46 ? If so where did you purchase and how did you install the doom light?
| | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | change your topic header it scared me | | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | change your topic header it scared me | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I installed one in my '40. ( Note my truck is not stock - is 12v with new wiring harness and light switches )Picked up a generic one at Auto Parts store. Also purchased ( 2 ) plunger type switches to install in door jambs. Remember with dome light, power is always on. When you open the door, plunger switch completes the ground to make light come on. Also connects to headlight switch for on/off & dimming. | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | I picked up several at Pull-A-Part from late model vans & P/U's. They're more like a dome/map light with separate switches for the map lights. I think I gave $3.50 each for them. Two were chrome and the rest were plastic. I haven't used them but thought I might. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Good looking work you've done Gman. The only thing I'd change is to get that UT helmet off the firewall. lol
~Jim
| | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | Thanks, if there is any defense they're in a building mode (or thats what I tell myself). LOL. | | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | look in The Filling Station catalog,they have many to choose from. | | |
