7 members (Lostbuthaulinass, Southerntruck, Otto Skorzeny, gswbbc, Hotrod Lincoln, 2 invisible), 46 guests, and 3 robots.
Topics128,032
Posts1,055,521
Members48,425
#79439 07/02/2007 12:22 PM
Just wanting to know if there is any concern about the 261 having enough room on the frame to allow the cab to fit without touching the firewall to the engine.
I have just set the cab on the frame no bolting and it seems real close to the valve cover at the fire wall. Just wondering about any fit problems anyone has had. Thanks
sader dog
#79440 07/02/2007 2:08 PM
sader dog,
If you use your original clutch housing, flywheel and clutch assembly, the rear of the engine has tyo mount in the same location. Depending on your 261, you might have to adapt the front mount (maybe by using your original front mounting plate - maybe someone who hs done this will post).
The major possible problem is the water pump pulley/shaft protruding too far. Maybe some else will comment on this.
The lengths of the 216/old-235/new-235/261 blocks are the same. If I am wrong, we will hear about it.
Tim
#79441 07/02/2007 4:48 PM
Yes, 216,235 and 261 blocks are all the same length.
My Blog
#79442 07/03/2007 2:01 AM
Thanks for the info., I have redone the water pump and the fan. My main concern is how close the 261 is to the cab firewall.
sader dog
#79443 07/03/2007 2:11 AM
ODSS Lawman
ODSS Lawman
If you are using srock motor mounts, you will have no problem with the engine and the firewall. Check out my pics.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
#79444 07/03/2007 12:23 PM
Have a 261 in my '49 GMC half ton. The rear of the valve cover (Offy) is close to the firewall be clears it okay. No rubbing. In fact, I lengthened the cowl drain hose and put it behind the rear of the valve cover so it would dump water away from the cover itself. You may be able to see the clearances on some of the pics in my engine rebuild album. I have the single front mount and the two rear mounts on my 261.
http://community.webshots.com/user/geezer
Country Roads, West (By God) Virginia
