3 members (1955 1 Series, TUTS 59, 1 invisible),
141
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,934 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Boy, the title space just doesn't have enough room.
What I'm wondering is, what style traffic light viewer do you have? The "guide" style, or the other one. And, do you like 'em.
I'm about to put the visor on my panel, and I know from when it was on the 1-Ton, you can't see anything!
Thanks. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Although I have never had one, I would think that you need it mounted down on the dash. If it's up around the visor it can't pick up the light from the traffic signal. There is a hole in my dash right behind the center of the windshield and my speculation is that is what might have been there some time. EDIT: chalk this post up to my misunderstanding that I thought you had one on the one ton.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Christopher, Give us a part number/vendor for "the other one". I might not understand the matter raised by FGT regarding location of the viewer. The original viewers and the reproduction viewers that I have seen are installed on the dash, near/against the windshield. Both work fine and are conversation pieces. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | The best jokes are the ones you have to explain.  | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Christopher, I'll be putting my visor on this winter too, I've seen a Prizm traffic light spotter in a '52, it was on the left side, up against the windshield. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I put the "style 1" on my '38 simply because it's mountable using a windshield garnish molding screw through the base of the viewer. The other type has a stud mounting base. My traffic light viewer.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The one Tiny shows is the one shown in A-D literature and it is the one I have looked-through on other people's trucks. It works, and it is a conversation piece. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Great! I love flipping through your literature Tim. | | | | | Joined: Jan 2009 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 106 | Adding a visor to an AD truck really improves the comfort of driving the truck on a sunny day. I have used both styles of traffic light viewers and found them to work about the same. Both viewers work the best at night or on overcast days. It is more difficult to see the traffic light on a bright day and when facing the sun. I am using the clam shell type now. It is mounted to the moulding screw as described above. In addition to being functional, viewers are fun and interesting to folks who always want to know what they are.
Stovebolts are good for the heart
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Well, I ordered the viewer today, just for kicks, I ordered what I referred to as style number two. It's got a (well, okay I forked over another $7) magnetic base.
You can't have too-many gadgets in the old truck/car. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | If you guys would polish up your hoods you get a perfect reflection *g* | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | I have the fat prism style also but I put the magnetic base on mine. Took the visor off and still use the viewer. Some of the lights are directly overhead. It works great!
Good idea Brit , but my hood is "olskool" semi-black and has bout 100 louvers in it. HAGD | | |
