0 members (), 150 guests, and 0 robots.
Topics128,101
Posts1,056,180
Members48,436
I
I Offline
I have a 1962 Stepside 6 cyl/3 on the tree pickup that is very original with only 70K Central Oregon miles on it. We've rebuilt, overhauled or replaced everything to make it run very nicely. My one problem is the temperature sending unit is missing. My cylinder head is drilled and tapped for a 9/16" thread sending unit; the only replacement units I've been able to locate are 3/4" thread. My wiring harness has the "L" shaped two prong plug. Anybody know where I can find the correct sending unit?
'62 Chevy C10 Short Bed Step Side, 235 Six with Offy intake, 2 carter/weber 2bbls and Fenton headers. B-W T5 5 speed trans, with stock rear end.
maybe you need a different adapter, try local parts house, maybe NAPA.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Standard part # TS-15 is listed, but shows a 1/2" NPT thread.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
It sounds like you have a 1955 or older head, they are setup for a mechanical temp sender.
You may need to drill and tap your head or switch to a mechanical gauge..
My Blog
