Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (tclederman, Peggy M, Woogeroo, klhansen, J Lucas, 1 invisible), 55 guests, and 7 robots.
Topics128,010
Posts1,055,299
Members48,419
#79388 06/29/2007 3:21 PM
I have purchased 2 Carter Weber 2bbls and installed them in my '42 1/2T Pu on a '60 235/Offy intake. I have a problem with the carbs stumbling/popping upon acceleration (appears to be in the primary). It idles great, has a manifold heater and does not have any vacuum leaks. I believe the primary emulsion tube is too restrictive...I need the next size or so. The tubes are stamped 150 for the primary and 250 for the secondary...Is my assumption reasonable? Secondly, where do you find/buy replacement emulsion tubes...I've called a Weber vendor and he won't even talk about Carter Webers! Any suggestions or direction?
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
#79389 06/29/2007 5:54 PM
Advance the timing slightly and see if there is any improvement. 90% of the "carb problems" I've had have been ignition related. Maybe Carb King will have parts sources.
#79390 06/29/2007 7:38 PM
Carburetion specialist
carbking is unaware of any parts sources for the Carter Weber carbs.
Jon (carbking).
The Carburetor Shop
#79391 06/29/2007 8:30 PM
Carbking was kind enough to walk me through the basics of the Carter Weber situation and to help me explore other options. A patient and knowledgeable gent.
Does anyone know if Weber replacement emulsion tubes will work in the Carter copy?
Has anyone tried drilling the existing tubes to modify performance?
Steve G.
#79392 06/29/2007 9:04 PM
Just a suggestion.....I'm running the same carb setup...C/W's, Offy, fresh 1960 235+ into Fentons, stock dist, .72 T5, 3.42 diff, and 28" tall tire. Out of the box, they were near perfect. Great idle, no hesitation and clean burn with the secondaries.
However, I learned from my experience with the single Holley/Weber, that the stock fuel pump needed to be throttled down with a regulator. I'm now running 3.5 psi at the carbs and couldn't be happier. I bought an inexpensive regulator and gauge from Azone.
I don't know if this will help you with your problem but it works for me. I just can't imagine that with your timing on the money that you'd be having to make any major changes to the jetting.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
