2 members (NJC, 1 invisible), 109 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#791336 10/23/2011 12:28 AM
I replaced the SM420 in my 55 with a S10 T5 and through the tech pages followed the tutorial by "steppenwood" on shortening the throw. Excellent tech tip and worth the effort. I used the original arm from my 55 and welded onto the S10 shifter assy for an original look.
1955 Chevy 3100
i am maunfactoring the short throw adapter email me if anyone is intrested
1949 SUBURBAN
Great idea John and well worth the effort.
1955 Chevy 3100
I made the same mod to my T5 using 1 inch square tube welded up to fit. I added sleeve inserts from round stock to prevent the bolts from crushing the adapter. Then I cut the stick off of an old SM420 and welded 2 thick 14mm nuts to the bottom so I could screw it on and off of the T5 shifter. The mod works great and keeps the throw short. Looks good too.
