1 members (klhansen), 92 guests, and 1 robot.
Topics128,049
Posts1,055,741
#792429 10/26/2011 5:43 PM
Does anyone know anything about charcoal canisters and fuel vapors? When my truck sets with a full tank of fuel, the vent tube on the tank really stinks, for days after driving the whole garage smells. I was thinking of some sort of vented can filled with charcoal or hitting the salvage yard for a charcoal can, plumbed to the tank vent to capture the vapors. As long as its vented, it should clean it self of fuel vapors when the engine is running. It would all be under the bed at the rear of the truck. Do you think standard cook out charcoal broke up would do the same as the crystal charcoal in vapor canisters?
Joe
Joe H #792600 10/27/2011 2:05 AM
Cooking charcoal is not likely to work at all for gasoline vapors. Even if it does work some the capacity will be so low it won't be useful. The charcoal in a canister from a salvage yard will still be good, it doesn't wear out.
Harold Wilson
41 Chevy 3/4 Ton
Joe H #792608 10/27/2011 2:24 AM
No. One is "activated charcoal", one isn't. I don't think you can get it to activated porosity by breaking it up. (10 grams with the area of a football field!)
TxLaTx #792741 10/27/2011 3:29 PM
OK, its off to the salvage yard to do some digging.
Joe
Joe H #792759 10/27/2011 4:50 PM
You activate charcoal by boiling it. Charcoal works by attracting the organics on a molecular level. The carbon will eventually reach a point of total absorbation. It will then either need to be replaced or re-activated. Same exactly as the filter for your house sink.
Make sure if you add a filter to the vent line it won't restrict the fuel flow.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
johntsmith #792766 10/27/2011 5:04 PM
You can buy activated charcoal at a pet store, for what it's worth.
