| | | Forums66 Topics128,052 Posts1,055,718 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 5,201 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,201 | Does anyone know anything about charcoal canisters and fuel vapors? When my truck sets with a full tank of fuel, the vent tube on the tank really stinks, for days after driving the whole garage smells. I was thinking of some sort of vented can filled with charcoal or hitting the salvage yard for a charcoal can, plumbed to the tank vent to capture the vapors. As long as its vented, it should clean it self of fuel vapors when the engine is running. It would all be under the bed at the rear of the truck. Do you think standard cook out charcoal broke up would do the same as the crystal charcoal in vapor canisters?
Joe | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Cooking charcoal is not likely to work at all for gasoline vapors. Even if it does work some the capacity will be so low it won't be useful. The charcoal in a canister from a salvage yard will still be good, it doesn't wear out.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | No. One is " activated charcoal", one isn't. I don't think you can get it to activated porosity by breaking it up. (10 grams with the area of a football field!) Bill | | | | | Joined: Feb 2000 Posts: 5,201 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,201 | OK, its off to the salvage yard to do some digging.
Joe | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | You activate charcoal by boiling it. Charcoal works by attracting the organics on a molecular level. The carbon will eventually reach a point of total absorbation. It will then either need to be replaced or re-activated. Same exactly as the filter for your house sink.
Make sure if you add a filter to the vent line it won't restrict the fuel flow.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | You can buy activated charcoal at a pet store, for what it's worth. Bill | | |
