1 members (1 invisible),
89
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 7 New Guy | | New Guy Joined: Nov 2006 Posts: 7 | I have a Offy 4 barel manifold that I want to use on my 65 292. It is plumbed for heat. The inlet and outlet are 1/4 and 3/8 pipe thread. 1st question is which is which? Question #2 is if I want to use this with a stock exhaust, minus the heat riser, is there a plate I use between them to keep the water from running into the exhaust. Thanks | | | | | Joined: Feb 2000 Posts: 5,198 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,198 | The inlet and outlet doesn't matter which one you for what, the water goes in, then out, its which ever is easiest to hookup and plumb. If you use a stock exhaust manifold, you will not use the plate or water, the exhaust will heat it just like the stock manifold.
Joe | | |
