0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#792735 10/27/2011 3:14 PM
I have a Offy 4 barel manifold that I want to use on my 65 292. It is plumbed for heat. The inlet and outlet are 1/4 and 3/8 pipe thread. 1st question is which is which? Question #2 is if I want to use this with a stock exhaust, minus the heat riser, is there a plate I use between them to keep the water from running into the exhaust. Thanks
fpontarolo #792742 10/27/2011 3:35 PM
The inlet and outlet doesn't matter which one you for what, the water goes in, then out, its which ever is easiest to hookup and plumb. If you use a stock exhaust manifold, you will not use the plate or water, the exhaust will heat it just like the stock manifold.
Joe
