| | | Forums66 Topics128,156 Posts1,056,871 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | I'd like to put an HB on my 56 235 that has 2 v belt grooves. One for Alt but Id like to run an ac in the future. Is there a certain year or is it up to the crank OD? Thanks Rick...... | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Here's what I did to put a 2 groove balancer on my 55.1 235. linkregards, Leon | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Chevy made a two groove pulley for the 235 Powerglide engine in the cars with power steering. Probably hard to find. I lucked out as my engine came out of a '53 chevy car with power steering. This was the first year power steering was offered......
Kurt
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | For megbucks, you can buy a chromed job from one of the hotrod suppliers. If I did that, I would have to paint it black! | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | there is several places that have new/rebuilt dampers. I'm pretty sure I saw several double pulleys when I was looking for my damper. Just google harmonic balancer, vibration damper something like that. | | | | | Joined: Sep 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 49 | You might try Damper Dudes. net | | |
