8 members (GA Boy, 55shaker, Jay R, 32vsnake, Goach2, Ridgeback, 3B, Charles in CA),
95
Mod | | | Forums66 Topics128,198 Posts1,057,270 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | I'm hooking up my heater since my 6v to 12v conversion. Can I use the same type of voltage reducer I used for my 6v wiper motor?
I would think so but I just wanted to check. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Some of the electrical gurus can give better info than I can, but this is what I would use for both wipers and heater. Or this one if you need 25 amps. (Same info that I posted earlier re: 6v radios in 12v systems.) It's what I will use if I ever get my electric wipers working. I have a 12v motor in my heater so I don't need a voltage reducer for it. That is a sweet looking '51 and a great family photo.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jan 2000 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 124 | You can buy a heater reducer from fifthaveinternetgarage.com/partscounter for $18.00 and live happily ever after.....
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have a previous post in the radio forum of the resistor you need. It costs $4.00 from an electronics supply. You need a 1 ohm 50 watt resistor. They come encased in aluminum and are made to attach to sheet metal for heat dissipation. example resistor
| | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | I was told the 6 volt heaters will work on a 12 volt system. I have 12 volt in my '55 1st series truck. Also have a '54 belair with 12 volt. I am using a 6 volt heater in both without a reducer. The belair has been working for 10 years. They both work well on 12 volt with no reducer. Both are like on steriods. Maybe the electrical gurus might have some input. | | |
