2 members (ronsway, Bill Hanlon), 106 guests, and 4 robots.
Topics128,172
Posts1,057,035
Members48,458
I haven't found in the manuals if the '54 235's used the large or small journal camshafts.
Can I tell what my truck has without pulling the cam?
If not, what's it likely to be, small or large, forged or cast?
'53 BelAir 261 3spd/OD 4dr
'54 3100 235 3spd
'79 C30 with a '51 235-'57Bellhousing-'67SM420-14bolt dually
'89 V3500 350/465/205 SRW CC
One Chevy just isn't enough.
Early 54 had small, late had large.
The easiest way to tell is to pull the distributor and look at the drive gear on the cam. Early cams have a 1/2" wide approximately gear and a late cam has a 5/8" approximately wide gear. See pic #29 in this LINK
My Blog
Thanks Dave
'54 3100 235 3spd
