| | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 101 | On my 54 3100 235 c.i. with Hydra-Matic tranny the throttle is sticking, and it's scarey. Installed a new Rochester B carb 2 weeks ago. Then adjusted my slipping Hydra-matic, and it shifts fine. Now today my throttle sticks. It will drop down if I tap the pedal a couple of times, but still isn't decelerating like it should. It is scarey when the truck is wanting to run away from me. What do you think?
Disciple
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Did you get a Rochester B or BC (with automatic choke, as originally equipped)? I doubt if this is the cause of your problem - just asking.
| | | | | Joined: Jan 2009 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 101 | It is a Rochester B. Since I have owned the truck it has always had the Rochester B.
Disciple
| | | | | Joined: Jan 2009 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 101 | I am not sure if it is the way I adjusted the throttle linkage from the trans. or if it is the carb. Any help out there?
Disciple
