| | | Forums66 Topics128,005 Posts1,055,261 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | Where is my problem. I put a new speedometer cable on my 48 chev panel and in about 1 mile there was a loud screech and the cable was broke at the transmission just like the old one.
One other thing is I did not mark all the wires and I do not have a wire going to the battery from the generator to charge. Thanks for your help | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Join the crowd with speedometer issues. The wiring has nothing to do with the speedo cable, it is mechanically driven. Is your driven gear plastic or steel? My steel gears are getting mashed, but my cable is still intact. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Theres most likely a kink, or some other obstruction in the housing. Unscrew the other end off the back of the speedo, and see if the cable turns. | | |
