Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (SWEET, Wickedbass, Hanks custodian, HandyAndy, Ponchogl), 40 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#792227 10/26/2011 1:40 AM
On my 54 3100 235 c.i. with Hydra-Matic tranny the throttle is sticking, and it's scarey. Installed a new Rochester B carb 2 weeks ago. Then adjusted my slipping Hydra-matic, and it shifts fine. Now today my throttle sticks. It will drop down if I tap the pedal a couple of times, but still isn't decelerating like it should. It is scarey when the truck is wanting to run away from me. What do you think?
Disciple
Ted W #792231 10/26/2011 1:49 AM
Did you get a Rochester B or BC (with automatic choke, as originally equipped)? I doubt if this is the cause of your problem - just asking.
It is a Rochester B. Since I have owned the truck it has always had the Rochester B.
Disciple
Ted W #792689 10/27/2011 11:17 AM
I am not sure if it is the way I adjusted the throttle linkage from the trans. or if it is the carb. Any help out there?
Disciple
