Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
8 members (Hotrod Lincoln, farmallb, Chip O, tclederman, Charles in CA, Otto Skorzeny, Stovebolt48, TooMany2count), 46 guests, and 0 robots.
Topics128,006
Posts1,055,272
Members48,418
#792198 10/26/2011 12:28 AM
Where is my problem. I put a new speedometer cable on my 48 chev panel and in about 1 mile there was a loud screech and the cable was broke at the transmission just like the old one.
One other thing is I did not mark all the wires and I do not have a wire going to the battery from the generator to charge.
Thanks for your help
Leo Offline
Moderator
Moderator
Join the crowd with speedometer issues. The wiring has nothing to do with the speedo cable, it is mechanically driven. Is your driven gear plastic or steel? My steel gears are getting mashed, but my cable is still intact.
Theres most likely a kink, or some other obstruction in the housing.
Unscrew the other end off the back of the speedo, and see if the cable turns.
