Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (MNSmith, dt235sd, J Lucas, Hotrod Lincoln), 199 guests, and 6 robots.
Topics128,288
Posts1,058,579
Members48,492
#79187 06/25/2007 12:03 PM
Every once in awhile the oil pressure goes down to zero on my '55 2nd series. The engine sounds a little louder too so I don't think it's the gauge. It happens at idle and while driving. Any ideas? It doesn't do it all the time, just once in awhile and then it's fine. It does have fresh oil in it.
#79188 06/25/2007 12:28 PM
could be a plugged up line ...or there is somethin internal gettin ready to go bye bye ..?if you are noticin a change in the sound of the motor ....
How many miles or yrs so to say since it been apart ?
1952 Chevy Shortbed
Photos in Photobucket
#79189 06/25/2007 12:47 PM
I read a post one time by a very respected VCCA member who was having this problem. It turned out to be that the distributor was not set right and it would sometimes fail to turn the oil pump.
1951 1 Ton Completed
#79190 06/25/2007 2:56 PM
I'll check the distributor. Unfortunately, I have no idea if this thing has ever been apart. I know that it looked good when I had the pan off to replace the gasket, but who knows.
#79191 06/26/2007 1:50 AM
I noticed mine wasn't seated all the way the other day and the reason I noticed was the rotor seemed loose, that is I could rotate it maybe ten degrees without it springing back. Once I pushed the distributor down the play disappeared.
#79192 06/26/2007 3:06 AM
apbmalibu
When you had the pan off??? Did you use silicone when you put it back on? you may have some hardened silicone floating around in your engine. I saw this happen in an 351 f%*d engine once.
#79193 06/26/2007 12:00 PM
All I used was a little glue.
