1 members (stlcardinalsguy),
115
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79187 06/25/2007 12:03 PM | Joined: Jul 2005 Posts: 66 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 66 | Every once in awhile the oil pressure goes down to zero on my '55 2nd series. The engine sounds a little louder too so I don't think it's the gauge. It happens at idle and while driving. Any ideas? It doesn't do it all the time, just once in awhile and then it's fine. It does have fresh oil in it. | | |
#79188 06/25/2007 12:28 PM | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | could be a plugged up line ...or there is somethin internal gettin ready to go bye bye ..?if you are noticin a change in the sound of the motor .... How many miles or yrs so to say since it been apart ? | | |
#79189 06/25/2007 12:47 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I read a post one time by a very respected VCCA member who was having this problem. It turned out to be that the distributor was not set right and it would sometimes fail to turn the oil pump. | | |
#79190 06/25/2007 2:56 PM | Joined: Jul 2005 Posts: 66 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 66 | I'll check the distributor. Unfortunately, I have no idea if this thing has ever been apart. I know that it looked good when I had the pan off to replace the gasket, but who knows. | | |
#79191 06/26/2007 1:50 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I noticed mine wasn't seated all the way the other day and the reason I noticed was the rotor seemed loose, that is I could rotate it maybe ten degrees without it springing back. Once I pushed the distributor down the play disappeared. | | |
#79192 06/26/2007 3:06 AM | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | apbmalibu When you had the pan off??? Did you use silicone when you put it back on? you may have some hardened silicone floating around in your engine. I saw this happen in an 351 f%*d engine once. | | |
#79193 06/26/2007 12:00 PM | Joined: Jul 2005 Posts: 66 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 66 | All I used was a little glue. | | |
