4 members (dt235sd, Rich'sToys, wilbur53, Stovebolt48), 173 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
#79140 06/24/2007 11:32 PM
I wired it up by connecting the positive of the battery to the starter, and another wire from the positive going to the resister and from the resister to solenoid of the positive and the negative solenoid to the ground on the distributer, but when i wired it up the solenoid heats up and it smells like its burning up..why is this? or how can i wire it up so i wont have this problem. THNX
#79141 06/24/2007 11:43 PM
the resistor wire goes to the coil, NOT the solenoid .... tho I think that's what you mean - and the other side of the coil goes to the stud on the dist [to points inside], NOT ground - if your coil is heating up it prolly means that you don't have it switched, hooked like you say is like leaving the key on all the time, engine running or not
assuming you are trying to have a useable truck, not just "testing" things, the hot wire from the batt to the ign resistor needs to go thru the key switch
#79142 06/25/2007 12:29 AM
CHEVY50,
In stock form, aren't GMC's of this vintage positive ground. Maybe your engine is in a different rig or someone has already changed system polarity...hopefully!
Stuart
#79143 06/25/2007 12:33 AM
If it was switched to twelve volts(wire to resistor), the polarity would probably have also been switched.
#79144 06/25/2007 2:46 AM
Baldy,
Good point...I missed it.
Stuart
#79145 06/25/2007 5:03 AM
Chevys until the 55 were positive ground I believe.
I could be wrong. I know the early 50s were. I could be wrong about that as well.
~Jim
#79146 06/25/2007 5:50 AM
BIG CHEVY 3600,
I'm pretty sure Chevrolet never used a positive ground system. If they did, it might have been in the dark ages, but, I too could be wrong. smile
Stuart
#79147 06/25/2007 12:03 PM
I never had a chev that was pos ground. I do have 2 old GMC that are pos groung,however. Just my $.02
"Sometimes my luck is so bad that if I bought a pumkin farm, halloween would probobly be outlawed."
#79148 06/25/2007 12:30 PM
ya Dont think lucas was ever involved in a chevy do ya ?..OMG
1952 Chevy Shortbed
Photos in Photobucket
#79149 06/25/2007 10:09 PM
It must have been some sort of teenage greasemonkey myth. It was something talked about like how to prevent someone stealing your spinners. I wonder why GMC would be pos. grn and chev not.
~Jim
