1 members (Otto Skorzeny),
201
Mod | | | Forums66 Topics128,091 Posts1,056,387 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79137 06/24/2007 11:23 PM | Joined: Apr 2007 Posts: 6 New Guy | | New Guy Joined: Apr 2007 Posts: 6 | There is a "T" valve on the front of the engine and the oil spills out when i crank it since it is not plugged.Where is the oil supposed to be directed | | |
#79138 06/25/2007 2:01 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 |
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#79139 06/26/2007 1:18 AM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | One line from the T should go to the oil filter and the other will go to the front of the cylinder head to get oil to the rocker arm shaft.
The line to the front of the head should have a restriction fitting in place in order to limit oil flow to the rocker arms/valve train.
Do not run the engine without the line in place to the rocker arms. | | |
