Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Bill Marlow, Otto Skorzeny, baldeagle, EchoBravoSierra, Jon G, Jeff Ogden), 38 guests, and 3 robots.
Topics128,005
Posts1,055,266
Members48,418
Guys my tail lights stopped working and I would like to know how the light switch comes out. Its the pull out sort. My headlights are connected via a toggle switch so its seperate. I have the pull-out switch connected to taillights and dome light and odometer speed etc box
1959 CHevy Apache
3B Offline
Hy mejia11, if we're talking about a stock 59 Chevy light switch, then remove one battery cable, now pull the switch into the headlights on position, now reach under the dash and find the spring loaded button (opposite side to the wires), depress the button and pull the shaft out of the switch. Now you can remove the bezel nut with a slotted screwdriver, and the switch should now be able to be removed from the dash, hope that helps.
