1 members (Ole49GMC),
109
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Hello! I want to get the horn working on my '59 Apache, but here's what I have on the steering wheel...basically nothing (click on link below). Can anyone lay out for me exactly the parts I'll need, and maybe point me to a schematic of how things are set up on the steering wheel? I found the horn wire socket under the dash, and the relay and horns are still there, so I'm not going to worry about that part of things now. I'd appreciate any help anyone can give me. Thanks... Chris http://i904.photobucket.com/albums/ac248/barsteel/100_0083.jpg
| | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Chris,
There's a spring with a copper end that goes down in that hole. Also available is a kit that screws into your steering wheel. Your horn cap goes onto that.
I'm sure someone will advise of the part numbers.....I don't have them.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | |
