4 members (cmayna, klhansen, delwrench, TUTS 59), 83 guests, and 4 robots.
Topics128,190
Posts1,057,223
Members48,465
Can anyone tell me where I can get the springs that go on the door brace where the interior handles attach.
Maybe try Jim Carter Truck Parts or Chev's of the '40's ?
1940 Chevy KC 1/2-Ton
I didn't think there were springs at the interior handle? The latch itself has a spring which returns the handle though the flat linkage.
If you're talking about the springs that keep the EXterior handles from drooping, Jim Carter was where I found mine. Maybe they have the ones you're looking for as well?
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
If you look at the door braces where the interior handle attaches there is a spring on that lever
Huh, mine are gone but I think I see the mounting points on the brace and the lever backing plate/disc. Mine are working well enough without them relying on the spring internal to the latch.
