1 members (Alex52),
136
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 66 | Can anyone tell me where I can get the springs that go on the door brace where the interior handles attach. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Maybe try Jim Carter Truck Parts or Chev's of the '40's ? | | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | I didn't think there were springs at the interior handle? The latch itself has a spring which returns the handle though the flat linkage.
If you're talking about the springs that keep the EXterior handles from drooping, Jim Carter was where I found mine. Maybe they have the ones you're looking for as well?
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | | Joined: Dec 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 66 | If you look at the door braces where the interior handle attaches there is a spring on that lever | | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | Huh, mine are gone but I think I see the mounting points on the brace and the lever backing plate/disc. Mine are working well enough without them relying on the spring internal to the latch.
