8 members (fonz8261, FrankenChevy, baldeagle, Peggy M, tclederman, TexasJim50, carbking, 1 invisible),
46
Mod | | | Forums66 Topics128,018 Posts1,055,341 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 117 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 117 | What is the common method of installing the balancer on a 235 chevy six? The crank isn't threaded so there must be a trick. Drill the end or the crank and tap? stand the motor up in shop press and push it on? Help set me straight on this so I don't screw somthing up. Thanks, Chuck | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy CayoRV, the original method was to hammer it on, however there was a tool that installed over the balancer to stabilize (hold) all the elements of the balancer together, so that the bond between the elements was not broken. I drill and tap the ends of all my crankshafts on my engine rebuilds to fascilitate balancer installation. I think there is someone on this board that loans out the tools to do this job in place, is it Hotrod Lincoln? | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Heat the balancer hub with a Propane torch to expand it, and use a hardwood block and a BFH to tap it on. Don't get it hot enough to damage the front oil seal, but too hot to touch with your bare hands works pretty well. Work quickly, or the hub will lock down partway on and require some heavy hammering to seat it all the way.
I have a drill/tap jig available for loan to fellow stovebolters with a small security deposit, and a jackscrew type installer once the crankshaft snout is threaded. The older type balancer with the hand-crank lugs requires some machining to make a shoulder for a washer to pull against if you decide to bolt the 216 balancer on. Jerry
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | IDK if this is hot enough to affect the seal, but I've used boiling water to heat parts for easier fit. Don't try to pick this up out of the pot with bare hands, or even cloth gloves! | | |
