1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | I bought a 54 chevy truck 3100 and it had a open drive rear end . I took the rear end to a driveline shop today and im trying to find out what year it is . Im think its either a 551st or 55nd series rear end . they told me it has 4.11 gears and the number on it is AG206 . Im hoping its the 2nd series rear end so i can run the 3.38 gears . heres a pic of the rear end. http://s20.photobucket.com/albums/b212/espinoza720/?action=view¤t=a4616f3d.jpg
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy big_dan_1950, from my memory, that looks like a second series 1955 - 59 rear axle, now what was my name again | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That could be a '55 first rear end. If there is evidence that spring perches have been removed from the top of the housing it will be the later one. Either way the 3.38s should fit. | | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | i want to make sure the 3.38s will work before i buy them | | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | well just bought the 3.38 gears and installation kit i hope it will work | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's a '55 2nd w/4.11 gears, according to the code.
Bill Burmeister | | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | did you check the code online or in a book ? | | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | thank you very much longbox55 for all your help | | |
