10 members (Bill Hanlon, pdlightning, 1955 1 Series, dt235sd, mo2cyl, FAST55, Steelonsteel, MikeE, sron48, klhansen), 75 guests, and 3 robots.
Topics128,050
Posts1,055,667
#789688 10/18/2011 1:09 AM
I bought a 54 chevy truck 3100 and it had a open drive rear end . I took the rear end to a driveline shop today and im trying to find out what year it is . Im think its either a 551st or 55nd series rear end . they told me it has 4.11 gears and the number on it is AG206 . Im hoping its the 2nd series rear end so i can run the 3.38 gears . heres a pic of the rear end.
http://s20.photobucket.com/albums/b212/espinoza720/?action=view&current=a4616f3d.jpg
3B Offline
Hy big_dan_1950, from my memory, that looks like a second series 1955 - 59 rear axle, now what was my name again
3B #789730 10/18/2011 2:41 AM
That could be a '55 first rear end. If there is evidence that spring perches have been removed from the top of the housing it will be the later one. Either way the 3.38s should fit.
Cletis #789734 10/18/2011 2:46 AM
i want to make sure the 3.38s will work before i buy them
well just bought the 3.38 gears and installation kit i hope it will work
It's a '55 2nd w/4.11 gears, according to the code.
Bill Burmeister
did you check the code online or in a book ?
thank you very much longbox55 for all your help
