0 members (), 100 guests, and 3 robots.
Topics128,080
Posts1,056,317
Members48,442
#79025 06/21/2007 1:42 AM
I have sprung a leak from the water pump shaft seal. The engine serial number indicates it is a ’48. I have the fan and the water pump off of the engine but can not separate the fan belt pulley from the water pump shaft. I have tried all the usual tricks, soaking it with penetrating oil, heating the boss on the pulley, and two different gear pullers. The first started to bend the outside rim of the pulley, the second attached to the fan mounting screw holes started to bend the center section of the pulley. Still the pulley boss will not slide off of the water pump shaft.
What am I massing?? Are there other tricks?
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#79026 06/21/2007 2:21 AM
Kip's41,
I'll hazard a guess or two. The pulley is pressed onto the shaft and requires a proper setup and press to remove. Have you found a repair kit for this pump...you're planning on repairing it yourself. I didn't think repair kits were available. The easiest route would be a rebuilt pump, and it will probably come with a
pulley installed.
It sounds as though your bent pulley is toast now. Have you researched a rebuilt or new pump?
Stuart
#79027 06/21/2007 3:12 AM
The rebuilt pumps are available....I got mine from NAPA....you have your choice of a 3/8" pulley or the 5/8". Took a day to get it shipped in. Think it was about $54.00 with the old core.
I've tried removing the pulley..it's cast and even with the proper pullers I wound up breaking a chunk out of it.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#79028 06/21/2007 4:23 AM
I've been looking for months for rebulding kits and they are no longer avalable anywhere.
I got mine apart ok the flange and pulley were bent a little but I straightend them in the lathe and indicated them in with a dial indicator. cleaned it all up by soaking in "De Rust It" then I had to re-assemble it with the old bearing and seal because I couldn't find replacements.
Started her up and got a little drip from the vent hole on the bottom and finally ordered a brandy new one from Rock Auto, $80 with the shipping. I did a little right up about the new pump a week ago. All thumbs up!
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#79029 06/21/2007 8:30 PM
Ex Hall Monitor
Ex Hall Monitor
I got a rebuilt pump for my 38 from my FLAPS & it had the pully on it. All I had to do was install the fan. I think you're making a lot of work for yourself that you don't need.
#79030 06/21/2007 9:21 PM
I bought a rebuild kit off E-Bay for my 42 but ended up with a rebuilt. I think I still have the kit somewhere.
The crew that works on the \'42 --Sara, Hannah and Abby
#79031 06/21/2007 9:31 PM
Gents,
ALL the 216 water pumps that I have seen had the pulley SPOT Welded to the flange in 4 spots.
Its NOT rebuildable from that side,
You have to take it apart from the Backside after the plate comes off the back.
Leest thats what an oletimer told me, an the first thing back on the shaft is the new seal,etc etc etc....
Regards,
#79032 06/21/2007 9:47 PM
If you have a rebuilder in your area and it is a original GM pump have it rebuilt. I had one redone for our 46 and cost about $40 with a guarantee better than the locial parts store.
#79033 06/22/2007 1:05 PM
If you have the one hole in the back I have one I bought off ebay. With seal. Don't need it. My 216 is a 53 with the 2 holes. I need one of them. I think I paid $30 for it.
Just following the thread and for information.
Dennis
#79034 06/24/2007 8:17 PM
stevesr is correct. The only way to correctly remove the pulley is to press the shaft out from the back. Then insert the bearing/shaft assembly in a piece of pipe and press the shaft out of the pulley.
My Blog
#79035 06/25/2007 2:36 PM
Thanks guys for all of the advice, looks like a rebuilt unit. Just checked with the local FLAPS and they have one on order for overnight delivery.
#79036 06/25/2007 2:58 PM
Just out of couriosity Kip, what they gettin for a rebuilt pump in Michigan these days??
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#79037 06/25/2007 4:22 PM
$71.00 less a $20.00 core net $51.00. Over night delivery. I'll check when it gets here to see if I can determine where it was rebuilt.
#79038 07/13/2007 12:53 AM
Thanks Dave
For the backup,,,
Thought I was loosin it LOL.
Regards and as always,,
A Pleasure
Steve Sr.
