4 members (greenie-reddy, Bill Hanlon, Steelonsteel, 1 invisible), 62 guests, and 2 robots.
Topics128,208
Posts1,057,448
Members48,471
The door is so close it's removing paint. I also have to slam it at least 2 times to close. Do I need shimson the cab side or is it something else?
Have a look in the shop manual.
The passenger door was too-close to the cowl on my panel, it would bind. I was able to just loosen the hinge bolt on the door, and slide the door back a little. Works fine now, but I'm no bogyman, that might not be how you are supposed to do it. I stuck some blocks under the door to hold it up, as I figured without that it would surely sag down.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Better than my story.. The other weekend I noticed the fender piece (cowl?) near the door was warped outwards because the bondo was falling outward. I was so bad that it was stopping the door from opening, but I was able to just push the panel in with my foot as I opened the door. Then I go home a few weeks later to find that my Dad didnt see it and opened the door, peeling back some of the metal in the fender...
Moral of the story: adjust that door before you need a new fender all of a sudden!
Alex
57' 3100 (The Bondo Bandit)
Bad rust and worse wiring, but so much fun.
