| | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | The door is so close it's removing paint. I also have to slam it at least 2 times to close. Do I need shimson the cab side or is it something else? | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Have a look in the shop manual.
The passenger door was too-close to the cowl on my panel, it would bind. I was able to just loosen the hinge bolt on the door, and slide the door back a little. Works fine now, but I'm no bogyman, that might not be how you are supposed to do it. I stuck some blocks under the door to hold it up, as I figured without that it would surely sag down.
| | | | | Joined: Jan 2011 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 138 | Better than my story.. The other weekend I noticed the fender piece (cowl?) near the door was warped outwards because the bondo was falling outward. I was so bad that it was stopping the door from opening, but I was able to just push the panel in with my foot as I opened the door. Then I go home a few weeks later to find that my Dad didnt see it and opened the door, peeling back some of the metal in the fender...
Moral of the story: adjust that door before you need a new fender all of a sudden!
Alex 57' 3100 (The Bondo Bandit) Bad rust and worse wiring, but so much fun.
